1998 Chevy Blazer Looses RPMs and then gains it back
JEFFO1977
  • 1998 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 99,000 MILES
My Blazer hesitates while driving, It kind of lunges. It looses RPM for a sec then gains it back. I was wondring what could it be? Trany going bad, fuel filter, or bad fuel pump?
Wednesday, November 25th, 2009 AT 11:06 PM
Oxygen sensor
Catalytic converter
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Thursday, November 26th, 2009 AT 2:44 AM
