1998 Chevy Blazer has no power
1998 CHEVROLET BLAZER
153,000 MILES • 6 CYL • 4WD • AUTOMATIC
SIJONK9
  • 6 POSTS
Blazer idles fine but has no power when giving it a load. fuel filter is fine took egr valve off and drove it and the m/v ran the same no power when giving it a load. took catylitic convertor off and the vehicle still has no power. also replaced cap,rotor, coil. any suggestions?
Jul 6, 2009 at 2:36 PM
  • CERTIFIED EXPERT
  • 110,175 POSTS
Has the check engine light come on? My concern is the catylatic converter may be plugged. Have you checked that?
Jul 6, 2009 at 11:15 PM
SIJONK9
  • 6 POSTS
I took it off and still no power with load.
mtulipano@hotmail.com
Jul 10, 2009 at 3:34 PM
  • CERTIFIED EXPERT
  • 110,175 POSTS
Have you checked for vacuum leaks (intake)? Also, have you checked fuel pump pressure?
Jul 10, 2009 at 9:21 PM
SIJONK9
  • 6 POSTS
The fuel pressure is 60psi with engine on . i will now check it with engine off and key on. I took the cat/conv off and checked it. I also ran the m/v w/out the convertor on and the m/v runs the same. It idles normal and no power when giving it a load.
Jul 11, 2009 at 7:43 AM
  • CERTIFIED EXPERT
  • 110,175 POSTS
Let me know what you find.
Jul 11, 2009 at 8:00 PM
SIJONK9
  • 6 POSTS
I found that the fuel pressure is 52-54 with key on and engine off. I also hooked up my obd2 scanner and the scanner tells me it has to be connected to the m/v ( obviously it is connected) I then connected the scanner to another m/v and the scanner is reading fine but not when I hook it up to the 98 blazer.
Jul 12, 2009 at 7:12 AM
SIJONK9
  • 6 POSTS
The blazer is not idling anymore. I start it and it dies out.
Do you think fuel injector problems or sensors? I'm not a mechanic so my knowledge is limited.
Jul 12, 2009 at 8:41 AM
  • CERTIFIED EXPERT
  • 110,175 POSTS
It sounds more like a sensor. The fuel pressure is good. Make sure there isn't an intake gasket leaking.
Jul 12, 2009 at 10:47 PM
SIJONK9
  • 6 POSTS
Ok J+N,
I puuled the Spark plugs out and they are burnt to a crisp. I put in new plugs and tried to start it. It would not stay running. I pulled one plug out and it was black and smelled of fuel after only cranking the engine 3 times. I then cleaned that plug and returned it and pulled the fuel pump relay. The m/v started and ran rough for 10 sec then died obviously b/c of no fuel. Do u still think its a sensor or a fuel injector spider problem. If its a sensor what kind would it be. I'm sorry to sound like an idiot but i'm trying to fix this m/v. thx a bunch
Jul 13, 2009 at 6:54 PM
MTULIPANO
do you think it could be the fuel regulator. Again i get 62 psi when the enginge was running ( now its not) and 56 psi with engine off key on.
Jul 14, 2009 at 6:54 PM
MTULIPANO
The cannister that is attached to the engine pipe was clogged. I never thought to check that as I checked the cat/conv. Thx for the help though.
Jul 25, 2009 at 4:24 PM
