1998 Chevy Blazer Fuel Tank Capacity
TDDJSHIRLEY
  • 1998 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 125,000 MILES
We just purchased our 1998 Blazer used, and the original paperwork we found shows it has an 18 gallon fuel tank. However, the gauge shows empty (and low fuel light comes on) after only using about 12 gallons. Has anyone else had this issue or have any recommendations?
Thursday, June 10th, 2010 AT 3:18 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes it should be a 18 gallon (technically it is 17.963) tank and maybe get around 16 mpg in city. If the fuel light is coming on but you know it is not actually low than that usually indicates a failing / faulty fuel level sending unit which is in tank
Thursday, June 10th, 2010 AT 5:29 PM
