1998 Chevy Blazer Blazer shakes and viberates when I put it
1JESSY8
MEMBER
1998 CHEVROLET BLAZER
6 CYL
2WD
AUTOMATIC
119,305 MILES
My 1998 blazer shakes and viberates when I put it in gear and also the check engine light comes on and off. When I start diving it drives fine but when I come to a stop it has a viberation thats easly noticed it shakes alittle less when its just in park.
SPONSORED LINKS
Saturday, October 25th, 2008 AT 3:13 AM
MASTERTECHTIM
MECHANIC
You are describing a engine misfire. When was the last time you performed a full tune up? I recommend replacing dist cap, rotor and wires with new spark plugs. Thats where I would start.
Saturday, October 25th, 2008 AT 5:11 AM
MRPOLO
MEMBER
Hi, I have the same problem, also I am using way to much gas. I get about 11mpg. I did a Full tune up plugs wires, air fuel oil tranny filter, co2 sensor, still vibrating
