1997 Chevy Blazer Transmission Fluid Change / Now Transmiss
1997 CHEVROLET BLAZER
164,000 MILES • 6 CYL • 4WD • AUTOMATIC
JANGKYUNGMEE
I took my car in for an oil change at a Quick Lube place, and they had a special to change transmission fluid. I knew I needed this done because my mechanic in Grand Rapids (I recently moved to Detroit area) had told me a while back I needed this done. After the service, I noticed it was running differently. When I accelerated from stop, it was very sluggish and it wasn't shifting gears. Then it stopped driving altogether (found out the fluid had leaked out). I brought it back and he said his mechanic made 3 errors: Pinched the gasket, didn't use silicone and screws were too tight. He redid the service, but still same issues. My theory is that the transmission (which is just under 2 years old) got screwed up because I was driving it w/ virtually no fluid. He's saying I just need a new sensor. I'm bringing it back AGAIN today after work. I feel like I'm being taken for a ride, but I can't do anything about it....
Jul 8, 2010 at 12:47 AM
JIM SHIRRON
  • 77 POSTS
Do you have any reciepts?
Jul 8, 2010 at 1:01 AM
JANGKYUNGMEE
Do you mean for the fluid change that I just had? The receipt is very vague. It just says "trans service"...
Jul 8, 2010 at 1:04 AM
JIM SHIRRON
  • 77 POSTS
That's what a fluid&filter chahge is. Same thing happened to a friend w/a trans shop, guy took it to court, got a new trans & $5000
Jul 8, 2010 at 2:30 AM
JANGKYUNGMEE
So, does that mean I have to hire an attorney, etc.? That's a huge bummer.
Jul 8, 2010 at 2:36 AM
JIM SHIRRON
  • 77 POSTS
Yeah, but his settelment covered lawyer's fees. too
Jul 8, 2010 at 2:51 AM
