When I remove the pan from the trans are the solenoids easy to get at or do you have to go deeper?
Apr 27, 2008 at 8:22 PM
BUZZSAW
CERTIFIED EXPERT
[quote:0073248b2f="out53law"]Transmission problem
1997 Chevy Blazer 6 cyl Four Wheel Drive Automatic 150000 miles
When I remove the pan from the trans are the solenoids easy to get at or do you have to go deeper?[/quote:0073248b2f]
you may have to remove the valve body
Apr 28, 2008 at 10:42 AM
DENNYP
CERTIFIED EXPERT
solenoids should be at the rear of the valve body. You should be able to remove the retainer clips with a small pick.
