I recently had a new heater coil replaced, radiator flushed, and a new water pupm put in. Now that all of that has been replaced, my blazer is running about 230 degrees. Before I had trouble with the heater coil, it ran about 195 or 200 degrees. Could it be my temp gauge in the dash panel is bad? What could cause this? If I take the thermostat out it runs about 150 but my heat doesn't get real warm. What should I do?
SPONSORED LINKS
Friday, February 26th, 2010 AT 8:35 AM
