Just picked up a 1997 Blazer two days back and noticed when the vehicle is parked with the engine running, gas dribbles (pretty good drip) from under the car just in front of the rear drivers side tire. Someone I mentioned the problem to suggested it could be a leak in the gas reservoir? It only leaks gas when the car is parked and running it seems. The car is under warranty- only engine, transmission and drive train. I'm wondering first if this issue may fall under warranty. If not, given i've had the car only 2 days AND the issue is blatantly obvious, would the seller still be liable I wonder?
Jun 20, 2008 at 12:52 PM
