1996 Chevy Blazer RPM issues
SGTPENROD
  • 1996 CHEVROLET BLAZER
Engine Performance problem
1996 Chevy Blazer 6 cyl Four Wheel Drive Automatic
My chevy will not go above 2000 rpm, s while driving. I have already replaced the fuel filters, any ideas?
Monday, December 29th, 2008 AT 10:27 AM
HPI555
  • 11 POSTS
I own a 1997 chevy blazer and I had the same problem it turns out that my fuel pump was bad and had to be replaced. This does not surprise me because I have researced that this vehical had one of the worst fuel sytems gm ever made. Im very sorry if it is your pump hope that this helps! Or it could also be but im not 100% on this I would also check your coil pack as well. Also I would first get a fuel preesure gage and check your pressure it should be 60 to 65 lbs no lower than 55 it will cause it to run like this hope this helps.
Monday, December 29th, 2008 AT 11:16 PM
