1 cylinder at about 110-115psi-retest this cylinder.
Low compression in one cylinder usually indicates a bad exhaust valve
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
SPONSORED LINKS
Friday, April 4th, 2008 AT 2:33 AM
