1995 Chevy Blazer hesitating at start up running
DRELL1974
  • 1995 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 104,758 MILES
95 chevy blazer, during start up truck is running it sound like it going to cut off. Give it gas its fine. I can drive it, it drives fine. Was told in maybe the fuel injectors, cat converts clog, fuel filter or the fuel regulator. I replace the filter and the regulator and also the spark plugs cause gas was getting into the oil. What do u think it could be and what can I do or get to fix the problem
Saturday, January 31st, 2009 AT 12:16 PM
CYBERWOLPH
Read the post in this link, it tells a lot about the fuel injectors.. Not only that I have heard of so much gas draining into the intake, that it seeped in past the, poppets, into yhe cylinders, past the rings into the oil.. Strictly speculation on that one though.. But here some things to check for.. read this post and good luck
https://www.2carpros.com/forum/here-vp484339.html#484339
Friday, February 13th, 2009 AT 8:19 AM
