1995 Chevy Blazer hello
ROGER007
  • 1995 CHEVROLET BLAZER
Brakes problem
1995 Chevy Blazer 6 cyl Four Wheel Drive Automatic
how do I reset the ABS of my chevrolet blazer?
Saturday, June 12th, 2010 AT 4:13 AM
BMRFIXIT
  • 19,053 POSTS
Disconnecting the battery will reset all memory and codes
if light coming back on have to check for codes and fix
Saturday, June 12th, 2010 AT 1:39 PM
ROGER007
  • 38 POSTS
My problem is my 1995 Chevy blazer car, the brake of it in the back does not function, only the front brake function but not totally well. The ABS indicator lights up even though the engine is running, what could be the solution for this. Kindly advice. Thanks
Sunday, June 13th, 2010 AT 1:13 AM
BMRFIXIT
  • 19,053 POSTS
The function of the hydraulic system is the 1st to check
check brake fluid level and if leaking
make sure that you have no air in the system
try and bleed system at 1st
check if rear brakes adjust correctly
check wheel cylinders if frozen
Sunday, June 13th, 2010 AT 7:30 AM
