1995 Chevy Blazer fuel
BRESABEN
  • 1995 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 217,000 MILES
Truck shut off whale movein
Wednesday, June 16th, 2010 AT 11:30 PM
Do below
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Thursday, June 17th, 2010 AT 12:32 AM
Related General Content
