1995 Chevy Blazer Car doesn't turn over
PBRADLEY
  • 1995 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 150,000 MILES
I have a 1995 Chevy Blazer with a 4.3 liter V6.
When I went to start my car, after sitting for several hours, it started/died twice and now the engine does not turn over. I can hear and feel the starter trying real hard to crank it (lights dim), but the engine doesn't budge. I removed the serpintine belt - but it still doesn't crank. At first I thought the engine was siezed, but it cranked over briefly today. However, now it's wedged again.
My question is: is there any chance this could be caused by a failing starter? I read something about a stuck pioion in the service manual, but not sure if this is a standard transmission thing.
thanks in advance
paul
Saturday, April 12th, 2008 AT 6:04 PM
But it still doesn't crank. Test the battery make sure its 12.4 volts or higher-clean/tighten properly.
Have helper to hold key in start position while underneath bang on the starter-if it kicks over-replace the starter-If not check for power at the purple wire on the solenoid-power there again its the starter. No power present-backtrack it to the Park/Neutral switch and Ignition switch- see starter circuit below highlighted in green
https://www.2carpros.com/forum/automotive_pictures/12900_s1_7.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_s2_7.jpg
Saturday, January 30th, 2021 AT 9:40 AM
