1994 Chevy Blazer 5.1 4x4 350 134,000 miles
1994 CHEVROLET BLAZER
CBOB01@COX.NET
I am having a few different problems, the first one is there is a leaking head gasket on the drivers side of the engine. There isnt alot of leakage but there is some. The oil gauge is normally at 40 and it is at 60 then fluxuates back to 40. All the fluids look fine. When I start it up the rpm and idle are low and then dies out. I did a diagnostic check and it says it is running lean. I changed the plugs, wires, and did a full tune up on it. I also changed the gas filter and the 02 sensor. It will not idle right and I have to pump the gas to get it to run. Once it is warmed up it will run fine until it comes to a stop, sometimes it runs fine other times it has a low rough idle.The service engine soon light is on off and then stays on. I tried injector cleaner and that didn't seem to do anything either. Could it be the mass air sensor?
Oct 9, 2007 at 9:46 AM
LILWILLS
  • 49 POSTS
check ur throttle postiton sensor and your idle air control valve
Oct 16, 2007 at 3:59 PM
