1994 Chevy Blazer
14,500 MILES • 6 CYL • 4WD • AUTOMATIC
JERROLLS79
hi i have a 94 chevy blazer tahoe package and i am having some electrical issues. my passenger side blinker blinks very fast, i replaced the bulbs and nothing changed. the passenger side tail light worked intermittently before i changed the bulb and now the drivers side rear taillight doesn't work. Any idea whats happening? Thanks for your time
Feb 12, 2009 at 10:36 AM
  • 110,251 POSTS
Hi:
The fast blinking indicates a burnt bulb or the bulb isn't making a connection. Check the socket. Also, if both lights are out, make sure a fuse didn't blow. Also, make sure the front signal lamp is good. Finally, is the rear light socket part of a printed circuit or does it have individual sockets seperate from each other?
Feb 12, 2009 at 10:43 AM
JERROLLS79
yeah the passenger side rear socket is not very tight and there was some tan colored sticky residue inside both rear sockets. the front lights work with no issues. there is one bulb for reverse lights and one for running light, signal and brake. i only replaced the one for running signal and brake on both sides rear only. the fuse is good. thanks
Feb 12, 2009 at 9:54 PM
  • 110,251 POSTS
Hi:
The tan stuff is most likely an electrical grease used to keep things dry and corrosnion free. Have you checked the socket with a test light to see if you are getting power to it?
Feb 13, 2009 at 4:00 AM
JERROLLS79
yes i have power to it it works intermittently. the brake light works which is the same bulb i dont get it any ideas
Feb 13, 2009 at 11:14 PM
  • 110,251 POSTS
If I had to guess, there must be a damaged wire between the tail lights and the power supply. It could be a break in the wire that is internal making contact at times and not at others. Make sure the body grounds are ok. If they are and you're sure you have a good ground, the last thing to do is trace the wiring looking for the problem (which is a pain). Before you co crazy doing that make absolute sure the sockets are good.
Let me know what you find.
Feb 14, 2009 at 5:38 AM
