I changed 4 out of the 6 spark plugs (minus the rear right two looking from the front of the car which are blocked by the steering wheel shaft) to see if that would fix the problem. Still skips.
Next I take out the spark plug wires to see if they are the culprit. I checked for wear and tear and see nothing wrong with them.
Next leading problem would be the distributor but I don't want to tear that out just yet if I do not have to.
Thats when I started looking online for any advice.
If you could please see if you may be able to find the problem with me that would be great.
SPONSORED LINKS
Saturday, June 19th, 2010 AT 7:25 PM
