Hello !
Start checking the brake pedal switch (on top of the brake pedal) make sure that its good and sending the signal (+) to the brake lights, also be sure that the ground on the wiring harness is clean good and tight.
Good Luck and let us know on your findings!
SPONSORED LINKS
Wednesday, July 28th, 2021 AT 1:34 PM
