Last year I took a trip to Oklahoma. Before the trip I never had any problems with the Blazer. While I was in Oklahoma the truck started to have problems with starting in the morning, but once it was started it would start up with no problems untill the next morning after sitting through out the night. Since I have returned home the truck will not start at all. So far we have replaced:
Fuel Pump; rotor cap; button; spark plugs; spark plug wires; battery; distributor; coil; fuel filter; ignition switch; and the fuel regulator since January and the truck has still not started since. The fuel injector unit (also termed the Spider) was replaced four years ago. The timing has been set. What am I doing wrong?
Oct 1, 2010 at 11:06 AM
