1992 Chevrolet Blazer Clanking on Turns
OMGLOLETCETC
I have a Auto-Trans '92 S10 Blazer with 122,000 miles on it.
Everytime I make a sharp left hand turn, I can hear a really loud "clanking" noise coming from the front of the car. A friend of mine said it may be the trans-axel, but he wasnt really sure.
When I make right hand turns, I dont hear the noise really.
Any idea on what the noise is being caused by??
Sep 14, 2007 at 8:33 AM
BOOTDOG
  • 665 POSTS
he's right, as long it's a 4x4. sounds like a bad cv joint. replace the axle.
Sep 17, 2007 at 3:15 AM
RAYT333
  • 27 POSTS
Check the torsion bar mounts. they are on the cross member near the middle of the blazer.
Nov 1, 2007 at 12:09 PM
Suggested Repair
If the Blazer is 4x4, inspect the front CV joint and replace the axle. Also check the torsion bar mounts on the crossmember.
Conversation Summary
The owner of a 1992 Chevrolet S-10 Blazer reports a loud clanking noise from the front during sharp left turns, but not right turns. An expert says that if it is 4x4, a bad CV joint is likely and the axle should be replaced. Another reply suggests checking the torsion bar mounts on the crossmember.
