1991 Chevy Blazer engine wont turn over
JEANJ53
  • 1991 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 240,000 MILES
One time starts right up, if you shut off and try to start it again it sounds like battery dead. Rrrr, rrrr
Friday, September 24th, 2010 AT 6:48 AM
JDL
  • 16,098 POSTS
I'd have to make sure the battery has a full charge and connections, coming and going from the battery are clean and tight on both ends. I'd also have to check the charging system. Some of the national brand autostores will test the starter for you, if you take it off and take it to them. If you have a digital multimeter I can help you with some testing?
Saturday, January 30th, 2021 AT 9:48 AM
JEANJ53
WE have tested starter, cleaned and tighten all cables. Tonight it wouldnt start, took off battery cables, put them back on and started right up. Shut it off and then wouldnt start again.
