1989 Chevy Blazer Fuel Gauge
JAMES8730
  • 1989 CHEVROLET BLAZER
  • V8
  • 4WD
  • 179,000 MILES
Just recently replaced my fuel pump, after installing, my fuel gauge is not correct, shows correct reading, then will go down to around 1/4 tank and eventually go back to being right again. Prior to fuel pump installation gauge worked perfect. Any ideas?
Friday, June 25th, 2010 AT 11:07 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Sounds like may have a loose ground connection at fuel sending unit
Friday, June 25th, 2010 AT 11:14 PM
JAMES8730
Im grounded to the frame, should I try scruffing my grounding point up a bit for a better connection?
Friday, June 25th, 2010 AT 11:16 PM
BLUELIGHTNIN6
  • 16,542 POSTS
If its got some rust or dirt on it then yeah scrape it til its shiny
Friday, June 25th, 2010 AT 11:20 PM
JAMES8730
Will try tomorrow, thanks!
Friday, June 25th, 2010 AT 11:21 PM
JAMES8730
Alright so after checking the ground from the sending unit im still getting the same reading. Could this be a possible gauge issue?
Saturday, June 26th, 2010 AT 2:04 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Possible but not likely since it was working fine before pump replacement, could be bad unit though if fuel pump failed the unit probably wasn't far behind unless you replace the entire unit and pump?
Sunday, June 27th, 2010 AT 12:20 AM
