I have replaced fuel filter and fuel relay. The engine is getting enough fuel to back fire in the carb but will not start.
Thursday, September 10th, 2009 AT 10:31 PM
MECHANIC
Check the fuel pressure to rule out the fuel filter, pressure regulator and fuel pump-Are you getting spark?
SPONSORED LINKS
Friday, September 11th, 2009 AT 12:00 AM
BLUEBEETLEME
MEMBER
Okay replaced fuel filter and fuel relay. Tried to start and carb backfire. Removed fuel tank to replace fuel pump and discovered 2 gals of fuel when gage reads almost 1/2. Put fuel tank back on and put in gas. Now engine start if pumping pedal. And will die when stop pumping pedal. Where is pressure regulator? Or is this still a fuel pump problem?
Saturday, September 12th, 2009 AT 12:16 AM
MECHANIC
Clean out the idle air control valve and test the TPS if it continues check the fuel pressure if its within specs
