1977 Chevy Blazer starter
1977 CHEVROLET BLAZER
FOURTWENTY420
Engine Mechanical problem
1977 Chevy Blazer V8 Four Wheel Drive Manual
One of the two holes on the block that the starter bolts into is stripped and cant tighten.whats the easiest way to fix this?
Apr 22, 2008 at 11:03 AM
ROB2008
  • CERTIFIED EXPERT
  • 258 POSTS
One thing you can do is drill out the hole with the next size larger drill bit ..and get a tap the size of the hole . then get a bolt that fits and tightin it up ..
-Rob
Apr 22, 2008 at 11:35 AM
