smell gas when i start it
FOXYTIGER
  • 25 POSTS
it is a 89 2.8 6cyl autotrans 1312299 miles i think i smell it later too i can smell it bad when srarting i have had pepole tell me its running rich i know it eats up too much gas it runs ruff sometimes its like it vibrateing hard it doesnt do it every time but it starting too i have replaced my 02 sensor map sensor cooling heat sensor belt tenson pully fuel filter thought that mite be leaking but no its not it set up for 2yrs bought from neighbor he had to much problems with it now there mine dont know what i got into reading all of the other problems on the site makes me wonder i guess im lucky so far its not worse dont know where to start with the gas problem any ideas would help thanks
Aug 19, 2007 at 12:41 PM
  • 75,988 POSTS
[quote:181718488d="foxytiger"]it is a 89 2.8 6cyl autotrans 1312299 miles i think i smell it later too i can smell it bad when srarting i have had pepole tell me its running rich i know it eats up too much gas it runs ruff sometimes its like it vibrateing hard it doesnt do it every time but it starting too i have replaced my 02 sensor map sensor cooling heat sensor belt tenson pully fuel filter thought that mite be leaking but no its not it set up for 2yrs bought from neighbor he had to much problems with it now there mine dont know what i got into reading all of the other problems on the site makes me wonder i guess im lucky so far its not worse dont know where to start with the gas problem any ideas would help thanks[/quote:181718488d]
Check the fuel pressure regulator,remove vacuum hose does it have gas, if so the FPR is ruptured. if not check the coolant temperature sensor could be stuck in open loop and computer is thinking it needs fuel but it doesn't because of its reading. Or excessive fuel pressure-you need a fuel gauge to do this.
Aug 22, 2007 at 10:03 PM
FOXYTIGER
  • 25 POSTS
thank you so much now i just have to find out where all the parts are i know where the coolant sensor is but thats about it these fuel injectors are new to me thanks agin for the info
Aug 23, 2007 at 5:24 AM
