1994 Chevy Beretta engine stops
MACKEZE
  • 1994 CHEVROLET BERETTA
  • 6 CYL
  • FWD
  • 12,000 MILES
Cold start engine runs for 10 min. Then dies. Engine wont start again for 30 min. When the engine stops it causes doors to lock! Idle is normal then stops abruptly; engine turns over but wont start
Friday, December 4th, 2009 AT 11:40 AM
JDL
  • 16,098 POSTS
Welcome to the forum, when it won't restart, Have a helper crank it, while you check for spark at the plugs, if you have spark everywhere, use a gage and check fuel pressure. How long since a tune-up?
Friday, December 4th, 2009 AT 12:10 PM
MACKEZE
I checked for spark, none! So I go an start it 1 hr. Later it starts, runs for 10 min. Then cuts off abruptly. Coils or ig. Cont. Mod.?
Saturday, December 5th, 2009 AT 11:00 AM
JDL
  • 16,098 POSTS
If you have bypass ignition, the ignition module controls spark during cranking, does the crank sensor plug into the ignition module? Possibilities, crank sensor-- ignition module-- wiring circuits. Any trouble codes?
Saturday, December 5th, 2009 AT 12:47 PM
