9-16-08 (84,390 miles) Took in to FS they said PVC valve missing along with hose. Replaced and put in engine sensor: AC107 Idle Air Control motor, then Throttle Body Gasket, and not sure if cleaned or replaced throttle body. 11-06-08 (84,636) took car back in stalled turning a conner. NOT running the way it did before accident, very low power, low idle no smoke. When turned on in past engine would reve up for a few 5-6 seconds then settle down to a strong, steady idle. Now no reving. At idle feels like it is about to die, so push on gas a lot. The 11-06 repair was Reman Air Mass Sensor. Tech sd. Rechecked after install and no trouble codes showing up. It has been drivable but still low power, low idle. But 11-17-08 stalled again when turning. I may not have been giving it gas in the turn. Engine light came on again. Slow cranking, but caught first try.( Have new battery and electricall system was checked in Feb. 08) oh joy.
SPONSORED LINKS
Wednesday, November 19th, 2008 AT 2:31 PM
