1960 Chevy Bel Air pcv valve
1960 CHEVROLET BEL AIR
670 MILES • V8 • 2WD • AUTOMATIC
LONNIE URICH
I have a '59 283 w/ 670 miles on a rebuild by a supposedly reputable shop. It originaly came w/ a road draft tube. I used the '64 pcv hose hookup that replaces the draft tube at the top rear of the block. It was from an incomplete parts engine, so i don't know which (if any) pcv valve was correct. I used a pcv valve in a blister pack from the parts store because it had the right threads for the carb base, and was the right hose size (1/2" i.d.). The valve is installed in the correct direction, I gave it the suck/blow test and it functions correctly. It only smokes a little on start-up.I'm using a quart of oil every 80 miles, blow-by rolls out from under the hood at the stoplight, there's oil spatter on the firewall (vented oil fill cap), the rear main seal leaks, all symptoms of a pcv problem, or rings that never seated. Do different valves have different cfm flow? which one's right? are my rings FUBAR?
May 31, 2009 at 10:51 PM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
pcv valves do have different flow rates. to answer your first question. What you describe is to much pressure in the engine.either go back to the original system or make sure the pcv valve is working correctly. If your engine is working correctly you should have no more than 3-5psi pressure on your engine breather . You either have a huge leak at the back of the intake (china wall) which can be sealed by silicone instead of the cork gaskets. to see if your rings have seated , do a leakdown test. Just go on the internet and lookup cylinder leakdown test or take it to a reputable shop and see if they can do it. I would see if you can find the correct pcv valve for the 64 that you stole the parts from to see if it woud correct the problelm...
Sep 14, 2009 at 3:03 PM
TECH1JONES
  • 10 POSTS
Smoke just after startup tends to be worn valve guides/ or leaking valve seals.. sometimes overlooked when fixing the bigger problems.
just an fyi
Nov 20, 2009 at 11:56 AM
