2003 Chevy Avalanche cylinder misfire
CARL KINGSBURY
  • 2003 CHEVROLET AVALANCHE
  • V8
  • 4WD
  • 89,000 MILES
What would cause #4  cylinders to misfire at the same time. And suggestions for repair
Sunday, June 29th, 2008 AT 11:00 AM
RHALL77
  • 3,361 POSTS
Possible bad head gasket, bad injector wiring, bad PCM, bad plug wires, injectors need to be cleaned. Most likely a vaccum leak at the intake manifold. There can be a whole list of things. Did you check to see if thre was spark at the plug wires and injector pulse at the fuel injectors. Also check for a vaccum leak at that point of the intake
Monday, June 30th, 2008 AT 7:52 AM
