2002 Chevy Avalanche Green plastic piece, switches blinker
DISCONTENT
Steering problem
2002 Chevy Avalanche V8 Two Wheel Drive Automatic 188XXX miles
Ok, so i have replaced my entire ignition assembly attempting to fix my problem. In order to get to the ignition screws i had to remove the circular green piece that trips the blinker off after a turn.. This piece has a very tough spring behind it and a *snap ring* to hold it in place. Is there an easy way to compress that spring to get that snap ring to pop in its proper place? i cant seem to get it past the first groove. thanks
Oct 15, 2010 at 8:11 AM
HMAC300
  • 48,601 POSTS
i think you are talking about the spring that holds the lock in place. there is a tool that screws on the end of the steering shaft and will push the spring down. should have been used forremoval too....... an auto parts store may rent that tool.
Oct 17, 2010 at 7:23 AM
