2002 Chevy Avalanche Engine revs when shifting between gear
2002 CHEVROLET AVALANCHE
90,000 MILES • V8 • 2WD • AUTOMATIC
SYNTEXROY
When taking off the engine revs when shifting between 1st and 2nd and also 2nd and 3rd. If you are taking off fast it won't shift until you let up. The check engine light will come if it red lines. After a day the lights goes off. If you take off slow everything works great. This is the origanal Trany.. Thanks for any help.
Jan 28, 2009 at 11:43 PM
DENNYP
  • 1,824 POSTS
Check the fluid level. If it's full, the transmission will need to come apart for inspection.
Jan 29, 2009 at 10:50 AM
SYNTEXROY
Thanks for the info!!
Jan 30, 2009 at 5:05 AM
