2002 Chevy Avalanche
COCONUT
  • 2002 CHEVROLET AVALANCHE
Engine Mechanical problem
2002 Chevy Avalanche V8 Four Wheel Drive Automatic
My 02 Avalanche has 148,000 miles. It died suddeenly. Turns over fine. Doesn't seem like it is getting fuel. Replaced fuel pump relay. Before I replace fuel filter, any otehr suggestions?
Sunday, August 24th, 2008 AT 4:02 PM
DENNYP
  • 1,824 POSTS
Check the fuel pressure. It probably has a bad fuel pump.
Tuesday, August 26th, 2008 AT 8:19 AM
COCONUT
Thanks, Denny. It looks like you ae correct. I changed fuel filter and still have the problem. Unfortunately the fuel pump is located inside the gas tank, which is too big of a job for me to do, so off to the shop. They will check fuel pump pressure.
Tuesday, August 26th, 2008 AT 9:25 AM
