2000 Chevy Astro Left Turn Squeak
2000 chevy Astro rear-wheel drive, 98,000 miles. When I make left hand turns I hear a rubber on rubber kind of squeeking noise, like two rubber parts are sliding on each other. It doesn't do it when I turn right and it does it worse if it's raining. Is it something to be concerned about, like a belt coming loose?
Apr 25, 2007 at 4:03 AM
Sorry for the late reply.
My thought would be to cut wheels all the way to the left, get the suspension to bounce up and down, see if you can recreate the noise. If you can recreate the noise, check your suspension components.
If it was serpentine belt, I think it would make the noise all the time. If the belt has a lot of mileage, replace it. If the removed belt appears to be in reasonable shape, you can keep it in vehicle for emergency spare.
Mar 18, 2015 at 7:14 AM
Just to add, struts can squeak, also, control arm bushings, just to name a couple.
Mar 18, 2015 at 7:22 AM
Suggested Repair
Turn the wheels fully left and bounce the suspension to recreate the squeak, then inspect suspension parts such as struts and control arm bushings. A serpentine belt is less likely if the noise occurs only on left turns; replace a high-mileage belt if desired and keep a sound removed belt as a spare.
Conversation Summary
The owner of a 2000 Chevrolet Astro reports a rubber-on-rubber squeak only during left turns, worse in rain, and asks whether a belt is coming loose. The expert advises recreating the noise with the wheels turned left and the suspension bouncing, then checking suspension components including struts and control arm bushings. A belt would more likely squeak constantly; a high-mileage belt can be replaced and a sound removed belt kept as a spare.
