1992 Chevrolet Astro Startup Smoke
SIMONK
  • 8 POSTS
i have a 92 chevy astro van,4.3l 136000 miles.when i start after sitting for an hour, it smokes but stops rightaway may be in a minute. it is sluggish to take off and on a hill unless i accelerate hard. service engine light came on and had it scanned for codes 13, 43,45. i changed the oxygen sensor and did a tune up but no change at all.please help.
Aug 17, 2007 at 3:25 AM
SERVICE WRITER
  • 9,123 POSTS
If I remember right the older astros had an oil burning problem from bad valve guides. Is the smoke bluish?
Aug 17, 2007 at 12:27 PM
SERVICE WRITER
  • 9,123 POSTS
As much as I respect Techmans opinion, i am hesitant to agree with this one. Older van and engine flush do not make me feel too comfortable. If you loosen up the gunk and it falls into the oil pan and gets sucked up to the pump screen, you may loses oil pressure...and lose the motor.
Doing an intake cleaing as Techman suggusted certainly is a good idea, but still doesn't explain th oil burning as I understand it.
Aug 18, 2007 at 3:51 PM
SERVICE WRITER
  • 9,123 POSTS
So defend your reply, don't throw stones. I have no problem learning something new. Why is the engine smoking IN THESE CONDITIONS and what color is the smoke? Why will an engine flush help? What in the world does the carbon build up have to do with a smoking engine IN THESE CONDITIONS? "Before I would worry about Service Engine Soon codes, I would dismantle the air intake and filter holder and scrub it" -I know what you mean on your above statement, but what are you saying to scrub? and with what? Why would you ignore the codes? Maybe an intake cleaning will help the acceleration, but it will it help? Peace brother,
https://images.2carpros.com/forum/automotive_pictures/30961_hippie_peace_1.jpg
Aug 22, 2007 at 10:03 PM
  • 75,988 POSTS
Hey, SW I remember this guy at Woodstock when he gave Carlos and Jimmy the doby-while Carol was doing her tunes. I thought it was Eric. It was a rocking place that day. Peace
Puff of smoke during initial start normally caused by worn out valve guides/seals and the oil will find its way in the combustion forming as carbon deposits raising the compression that will cause preignition and detonation.
He knock 13/45 due to contamination by changing it but 45 relates to the ESC equivalent to the old style of the canister's vacuum/centrifugal on a conventional distributor with contact points. A problem within the ignition advance and accelerator pump which is now known as the TPS will cause an hesistation and surging problem. Also to exagerate his problem could be a clogged-up converter bcuz of the snitchers are not working ruined by the oil.
Back in the 20th Century the CEL/MIL/SES along with its Parameters/Actuators was introduced to expedite diagnosis within the Electronic Engine Control as Ford calls it and GM with the CCC system. This is the starting point of troubleshooting back then and today it never changed. In todays technology the car is like talking to the tech thru electronic devices.
Aug 22, 2007 at 11:26 PM
Suggested Repair
Confirm whether the brief startup smoke is bluish, which points to oil from worn valve guides or seals. Diagnose codes 13, 43, and 45 rather than ignoring them, and check the TPS, ignition advance, and a possibly restricted converter for the hesitation. Avoid an engine flush on this high-mileage engine; intake cleaning may help drivability but will not stop oil burning.
Conversation Summary
The owner of a 1992 Chevrolet Astro 4.3L reports brief smoke after the van sits, sluggish acceleration, and service engine codes 13, 43, and 45 despite an oxygen sensor replacement and tune-up. Experts associate the startup smoke with worn valve guides or seals, disagree about an engine flush, and say the codes should be diagnosed. Intake cleaning and checks of the TPS, ignition advance, and converter were also discussed.
