1997 Chevy Astro Fuel Filter
HEIDIANDDYLAN
OUr 1997 Chevy Astro.... vin w...is having problems, it will drive normal for a little while then it looses power, starts to die, the oil pressure gauge drops and then it dies, some times it restarts just fine and runs normal, sometime when it restarts its all we can do to get it to go over 20 miles an hour. We are trying to replace the fuel filter, but can not find the Schrader valve to release the fuel pressure first...please help us out here, my husband is on leave from the Army and if we can get this fixed today he will be in a lot of trouble getting bcak late.
Oct 2, 2007 at 4:54 AM
BOOTDOG
  • 665 POSTS
you don't need to release the pressure to change the filter. just when you take loose one end of the filter aim the line away from you. most of the time after sitting awhile it will lose the pressure.
Oct 2, 2007 at 9:21 AM
Suggested Repair
You do not need a Schrader valve to relieve pressure before changing the fuel filter. After the vehicle has sat, residual pressure usually drops. When disconnecting one end of the filter, aim the line away from yourself.
Conversation Summary
The owner of a 1997 Chevrolet Astro asked how to find the Schrader valve to release fuel pressure before replacing the fuel filter, and also described intermittent power loss, stalling, and a dropping oil pressure gauge. The expert said pressure release is unnecessary; after sitting, pressure usually bleeds down, and the fuel line should be aimed away when the filter is disconnected.
