POWER WINDOW NOT WORKING WELL
CHEVROLET ASTRO
CRICKET
2000 CHEVY ASTRO VAN,70,000
SINCE I GOT NEW SPEAKERS PUT IN THE DOORS OVER A YEAR AGO I NOTICED THAT MY PASSANGER SIDE POWER-WINDOW DOESNT WORK AS WELL. THE DRIVER SIDE WINDOW WORKS JUST FINE. BUT ITS THE PASSANGER SIDE WINDOW THAT WILL GO DOWN SOMETIMES WELL, SOMETIMES A LIL AND WHEN COMING UP THE WINDOW ONLY DOES SO 1/4 OF AN INCH AT A TIME.AND DOESNT ALWAYS MOVE WHEN THE BUTTON IS PRESSED. SO I DON'T USE THE WINDOW. I WILL FINALLY GET IT UP A LIL AT A TIME THRU-OUT MY DRIVE OR BY REPEATINGLY TURNING ON THE VAN AND PUSHING THE SWITCH BECAUSE IT ONLY GOES UP A LIL BIT AT A TIME.
Aug 14, 2007 at 3:48 PM
MERLIN2021
  • CERTIFIED EXPERT
  • 17,250 POSTS
Check the connection at the back of the alternator, and the battery ground to the block...Must be CLEAN!!! Check alt wire when negative cable is dissconnected!!!
Aug 14, 2007 at 4:36 PM
