Transmission problem
2003 Chevy Astro Engine Size unknown Wheel Drive Type unknown Automatic 37000 miles
Last year when I had my oil changed the mechanic suggested a list of things to do for my chevy astro as regular maintenance. I couln't do this at the time. at the next oil change at a different place, the mechanic showed my the transmission fluid said that it looked good and was okay although chevy recommends flushing at 30000. I did have the fuel injection cleaned out at that time. Yesterday I went to the first place to have oil changed, tires rotated, balanced, and aligned, and van looked at since it was occasionally whining. They suggested transmission flush. I went ahead and agreed knowing that it was recommended by chevy. Later in the day a friend said that that was a big mistake. Now my transmission would fail and I would have all kinds of problems. After searching the internet, I have found varying opinions. Did I mess up? Will my transmission fail?
Thank you,
Lori
Thank you,
Lori
Feb 5, 2008 at 2:26 AM
