2002 Chevy Astro TUNE UP
211,000 MILES • 6 CYL • 2WD • AUTOMATIC
TLCCONT3184
WHERE ARE THE PLUGS LOCATED AND WHAT ELES SHOULD I DO TO TUNE UP THIS VAN
Apr 7, 2010 at 1:36 AM
FREEMBA
  • 1,152 POSTS
* The spark plugs are located about 3 -4 inches below the outer edge of the valve cover (on the sides of the engine---they screw into the side of the cylinder head).
* They are just above the exhaust manifolds along the side of the engine (hope these directions help). You have a V-6 engine so there are three spark plugs on each side of the engine. [follow the spark plug wires from the distributor]
Most tune-ups include replacing the spark plugs, spark plugs wires, distributor cap, distributor rotor, pvc valve, air filter and having the computer scanned for codes. Shops also view engine data (using a scan tool) before and after the tune-up to make sure that sensors are within preset parameters and to check engine timing advance, etc. some people also include the cleaning of the fuel injectors and throttle body.
Apr 11, 2010 at 6:01 AM
