MY ASTRO VAN WHEN YOU TURN SHARP LEFT OR RIGHT WOBBLES SOUNDS ALMOST LIKE A FLAT TIRE. HAD FRONT END ALLIGNMENT DONE NO CHANGE. TOOK TO MECHANIC. TOOK OFF FRONT DRIVE SHAFT AND ORDERED NEW ONE. DROVE FOR 3 DAYS DID NOT DO IT WITH DRIVE SHAFT OUT PUT NEW ONE IN AND IT'S DOING IT AGAIN. HE SAID IT COULD BE AXLE SHAFTS. DO YOU HAVE ANY IDEAS BEFORE I STICK MORE INTO IT WITHOUT A SOLUTION?
updated 12/10/09
Looked up more info on it found out its called wheel hop or crow hop changed transfer case fluid gm auto trak 2 transfer fluid it fixed the problem.
SPONSORED LINKS
Tuesday, December 1st, 2009 AT 11:02 AM
