Hi, thanks for the donation. When the problem occurs, are you saying, it cranks good but won't start? How long since a tune-up? Use a gage and check fuel pressure. Around here, some of the national brand autostores used to loan out a fuel pressure gage, if you don't have one. If you have the spider fuel system, fuel pressure can be critical. Also, the fuel poppets may need cleaning?
An idle problem, could be idle air issue? Taking the throttle-body off and cleaning, might help. Any trouble codes?
SPONSORED LINKS
Thursday, March 11th, 2010 AT 10:32 AM
