1999 Chevy Astro miss fires
KINGSMAN47
  • 1999 CHEVROLET ASTRO
  • 6 CYL
  • 152,000 MILES
When you first start it up it miss fires or just misses after the motor is hot it run good. I had bad gas in it now it's good gas with a v-checker reader on it it just saids miss fire
Monday, October 26th, 2009 AT 10:07 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Do you have the actual code it should be something like P0300 or P0301 - 306. If not your local parts store can pull the codes. Post them here.
Also when was your last tune-up?
Monday, October 26th, 2009 AT 10:30 AM
KINGSMAN47
I get bought it it's a nice van so I don't know when it was last tuned-up. The code was P0300
Monday, October 26th, 2009 AT 1:51 PM
OBXAUTOMEDIC
  • 3,711 POSTS
OK,
Here is the code def....
P0300 Random/Multiple Cylinder Misfire Detected
So, first thing I would do is pull a plug or 2 and see what they look like. If they look worn then I would do a tune-up and see if that corrects the problem. 8 out of 10 time is does.
If not other possibilities are....
Vacuum Leaks
Low Cylinder Compression
Weak Fuel Pump and/or Pressure Regulator
For more check out the link below...
https://www.2carpros.com/first_things/why_does_my_engine_run_rough.htm
Tuesday, October 27th, 2009 AT 10:06 AM
KINGSMAN47
Thanks for your help I had a vacuum hose that was broken in two
Tuesday, October 27th, 2009 AT 1:57 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, great did that fix the Misfire? If so congrats on the fix.
If not let me know so we can do more diagnosis.
Thursday, October 29th, 2009 AT 9:35 PM
