TEST AND DIAGNOSE COMPUTER OPERATIONS OF VEHICLE FOUND CODE P1870
Tuesday, February 19th, 2008 AT 4:32 PM
MASTERTECHTIM
MECHANIC
That code is transmission component slipping or pressure problem. There is a pressure plate on the bottom of the valve body that contains a series of sensors. This is usually the culprit.
