1995 Chevy Astro want crank
MELVINMILES
  • 1995 CHEVROLET ASTRO
Engine Performance problem
1995 Chevy Astro 6 cyl Two Wheel Drive Automatic 160.00 miles
hi and thanks, I have a 1995 astro 4.3 van shut off put new fuel pump on it, it ran good for 1 day the next day it cranked but while driving it shut off put on a new coil change fuel line filter had the piece on the distrubeter checked if was good put on a new dist button it tries to hit but want crank also made sure gas was getting to the air in line relese any help would be apprecheted melvin
Monday, February 9th, 2009 AT 2:28 PM
JDL
  • 16,098 POSTS
Hello, I saw what you replaced, did you do any basic testing? If your saying, it cranks good but won't start, have a helper crank it, while you check for spark at the plugs, if you have spark everywhere, check fuel pressure. Are there any codes?
Do you have the spider fuel system? They are noted for problems. Have you tried an injector cleaner, some people say seafoam helps, if it's a fuel issue.
Monday, February 9th, 2009 AT 2:42 PM
