I will make this as quick as possible. 1995 Chevy Astro, no power to fuel pump. If I jump the relay I get power to the pump. Relays are brand new. Also no power to radio, headlights and dome lights when key is turned ON. Also, no check engine light when key is turned ON. Attempted to use a code reader however code reader displays no connection. Unable to perform build in diagnostic since I dont have a check engine light.
I have spark to all cylinders (tested by starting fluid).
I'm thinking the ECM maybe?
Any thoughts?
SPONSORED LINKS
Sunday, January 25th, 2009 AT 1:05 PM
