Hello my car has a idle problem
I have check al sensors and ignition
if I remove and reconnect battery he idle good
for two minutes and then it goes wrong again
drive No problems
no error codes
Saturday, June 12th, 2010 AT 4:39 AM
MECHANIC
Try cleaning out the idle air control valve and see what happens-remember you disconnect the battery the IACV has to relearn itself
SPONSORED LINKS
Saturday, June 12th, 2010 AT 4:51 AM
BERT OOST
MEMBER
I had cleaning out the idle air control valve end replace valve
