1995 Chevy Astro
MICHAELALAN
  • 1995 CHEVROLET ASTRO
  • 6 CYL
  • 15,000 MILES
When ur driving after about fifteen minutes or so the motor trys to die. If u go up hill and u give it gas it does the same thing. Also when ur on flat ground and try to gun it it sounds like it going to die out.
Saturday, May 22nd, 2010 AT 8:19 PM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Saturday, May 22nd, 2010 AT 8:45 PM
