1995 Chevy Astro
BUBBA10
  • 1995 CHEVROLET ASTRO
Noises problem
1995 Chevy Astro Automatic
what is the name of the component in the top right position of the serpentine belt path? There is a knocking noise that accelerates and gets louder as I accelerate and it sounds like it might come from this component. At idle it is more of a muffled knocking.
Sunday, March 7th, 2010 AT 1:54 PM
  • 109,885 POSTS
Here is a picture of the belt layout and parts list.
https://www.2carpros.com/car_repair_information/year/1995/make/chevrolet/model/astro/1995_chevrolet_astro_drive_belt_routing_diagram.htm
Are you sure it is from there and not from the engine? You can check by removing the belt to see if the sound is still there. NOTE: If you remove the belt to check, do not run the engine longer than 8 to 10 seconds.
Thursday, March 11th, 2010 AT 9:57 PM
CABMAN86
  • 8 POSTS
Mine does that. Its the ac compresser knocking. I tried adding oil but it got worse. Dont know how to fix it tho. Havent taken it anywhere for an ac check yet
Friday, March 12th, 2010 AT 6:26 AM
