1994 Chevy Astro Dies Off Throttle
CAMORRALL
i have a 1994 chevy astro van its a 2w drive with a vortec engine 6 cylinder and it has 220,000 plus miles. my problem is that the van will start only with your foot on the gas pedal and as soon as you remove your foot from the pedal the car putters out. it will not stay started long enough to even put it in drive. what could my problem be?
Sep 13, 2007 at 7:21 AM
SERVICE WRITER
  • 9,123 POSTS
check the fuel pressure, it needs to be 9-13 psi with the key on and engine off.
Sep 14, 2007 at 2:12 AM
CAMORRALL
[quote:908def12c1="camorrall"]i have a 1994 chevy astro van its a 2w drive with a vortec engine 6 cylinder and it has 220,000 plus miles. my problem is that the van will start only with your foot on the gas pedal and as soon as you remove your foot from the pedal the car putters out. it will not stay started long enough to even put it in drive. what could my problem be?[/quote:908def12c1]
thanks for your help we found out what it was it was a clogged egr valve we cleaned the valve and it started right up
Sep 17, 2007 at 4:35 PM
SERVICE WRITER
  • 9,123 POSTS
Carbon build up can be nasty for runnibiliity. There are a fair amount of fuel pump problems and that was why I would have started there, not to mention fuel injector assys. Looks like its all acedemic anyways. Glad you solved your problem, and update the post.
Sep 17, 2007 at 9:55 PM
Suggested Repair
Clean carbon buildup from the clogged EGR valve. After cleaning, the van started and stayed running. If the stall returns, check fuel pressure; it should be 9-13 psi with the key on and engine off.
Conversation Summary
A 1994 Chevrolet Astro with a 4.3L Vortec six-cylinder would start only with the accelerator pressed and stalled as soon as the pedal was released. An expert first recommended checking fuel pressure at 9-13 psi with the key on and engine off. The owner later reported that a clogged EGR valve was the cause; cleaning it resolved the stall.
