1994 Chevy Astro No Speedomter and no shifting
CONGDONFAM
  • 1994 CHEVROLET ASTRO
  • 6 CYL
  • 17,000 MILES
I don't know what happened. All of a sudden the speedometer stopped, then the van wasn't shifting gears, I replaced the VSS and disconnected the battery to reset errors. The car still won't shift. Trans fluid was changed last year and filter, proper fluid levels.
Tuesday, July 20th, 2010 AT 11:56 AM
  • 109,885 POSTS
It soundslike the problem is coming from the VSS. If you replaced it, you need to start tracing wiring to make sure nothing is damaged or disconnected.
Let me know what you find.
Wednesday, July 21st, 2010 AT 11:34 PM
