The engine will start for a few seconds then dies. Dies even faster if you try to give it throttle. Any advice?
Saturday, March 21st, 2009 AT 11:19 PM
MECHANIC
Check the fuel pressure to rule out the fuel filter/fuel pump if okay try cleaning out the idle air control valve/test the TPS and MAF sensors and see what happens.
SPONSORED LINKS
Saturday, March 21st, 2009 AT 11:24 PM
JEEPMANMSR2
MEMBER
Ok already took every fuel/air sensor off the vehicle and had them tested and cleaned. Fuel pressure is 61 psi just replaced fuel pump, filter, cap and rotor sark plugs and wires and all wiring on the fuel pump 6 hours ago. Ran when all that was done then recently started this little trend.
Saturday, March 21st, 2009 AT 11:49 PM
MECHANIC
When it dies immediately check for fuel and spark something has to give here.
Sunday, March 22nd, 2009 AT 1:32 AM
JEEPMANMSR2
MEMBER
Ok did that its only pushing 48 psi but has good spark. Like I said brand new fuel pump filter and wiring
Sunday, March 22nd, 2009 AT 7:02 PM
MECHANIC
Is this a CPI or TBI fuel system
If its a CPI the pressure should be 60-66 psi and TBI 9-13psi
